Thema antwortete Hydraulix's matze133 in Baumaschinen Wartung, Reparatur & Diagnose
Hallo, ja, dann kommt Öl, dein Problem wird sein, dass sich zwischen dem Pumpengehäuse und dem Wegeventil ein spezielles Dichtblech befindet. die alten Dichtfragmente gehen eigentlich nur mit einem Schaber ab, die müßen aber runter, und dass Blech, oder heute ist es eine Folie mit Dichtung bedruckt. muß erneuert werden, !! Mit einem guten Werkzeug, an der das kurze Ende des Inbus noch mal gekürzt wird, also abgetrennt, und wie der Rookie richtig meint erst mal reinigen die Karre, dann etwas Rostlöser , und schon geht das leichter. Hydraulix -
Using a Bulldozer to Clear Land for Farming
ein Thema erstellte Strasser Earthmoving in Scraper & Schürfraupen
Clearing land with a bulldozer is a common and effective way to prepare a new field for farming. This powerful machine can handle tasks that would be difficult or impossible to do by hand. Here’s a more detailed look at the process. Initial Clearing and Piling The first step is to use the bulldozer's blade to push over smaller trees, shrubs, and brush. The goal here is to remove the top layer of vegetation and gather it into manageable piles. These piles, often called "windrows," can be burned later (where legal and safe) or hauled away. The process is much faster than manual clearing and is essential for getting a clean, open area to work with. Root and Stump Removal Once the surface vegetation is gone, you'll need to deal with what's left behind: tree stumps and root systems. A bulldozer excels at this. By using the edge of the blade, the operator can dig around the base of a stump to loosen it from the soil. The machine's sheer power then allows it to pop the stump out of the ground, roots and all. Removing these is crucial for farming, as they can damage equipment and interfere with planting. Grading and Leveling After the land is cleared of all vegetation and stumps, the final step is to grade and level the soil. The bulldozer's blade can be angled to scrape high spots and fill in low ones, creating a smooth, even surface. This is vital for ensuring proper drainage and making the land suitable for planting crops. A well-graded field is also easier to navigate with tractors and other farm machinery. While using a bulldozer is an excellent way to clear land, it’s a job that requires careful planning and skill. For the best and safest results, it’s often a good idea to hire an experienced professional. If you have any questions about earthmoving services, don’t hesitate to contact Strasser Earthmoving. Stay informed today. - Gestern
Verlegung der K158 Anfang April. Die MAN-Vierachser der Bunte Logistik fuhren unermüdlich Sand an die Baustelle, welchen sie von einem Naßabbau wenige Kilometer entfernt abholten. Diesen Abbau hatte Bunte erst vor wenigen Jahren erschlossen und dort schon einen großen Vorrat Sand auf Halde gelegt.
4.8.: Der R 924 verfüllt den Keller mit dem angefallenen Bauschutt. Dazu muss aber erstmal die Kellerdecke weichen... -
Auf der rechten Seite wird die Außenwand, die zur Stadtbibliothek zeigt, Stockwerk für Stockwerk zersägt und danach per Bagger herunter gezogen. -
Thema antwortete Rookie's matze133 in Baumaschinen Wartung, Reparatur & Diagnose
Erstmal ordentlich säubern, so kann man nicht an der Hydraulik schrauben. -
Hallo Hydraulix, habs mal mit einem wirklich guten Inbusschlüssel an den äußeren Schrauben versucht. Die ließen sich mit roher Gewalt tatsächlich lösen, nachdem ich schon befürchtet habe den Schlüssel abzureißen. Die hinten aber natürlich nicht, obwohl ich peinlich darauf geachtet habe tief genug im Sechskant zu sein... Es gab wie bei den äußeren etwas nach, das waren dann aber doch die Flanken vom Sechskant. Nun habe ich vor diesen ganzen Schieberblock abzuschrauben. Diese Schrauben konnte ich schon lösen. Bevor ich den Block aber abnehme wollte ich mal den Fachmann fragen, was mich da erwartet. Läuft da das ganze Öl vom höhergelegenen Tank nach? Besser eine Gummiplatte bereit legen, die ich auf die dann vermutlich freiliegenden Löcher spanne? -
Yanmar SV18 Oberwagen dreht sich Richtung Tal
Thema antwortete werkelkoenig's werkelkoenig in Baumaschinen Wartung, Reparatur & Diagnose
Hallo Hydraulix, vielen Dank für die schnelle Rückmeldung. Ich hoffe, dass ich am Wochenende zum testen komme und würde mich dann gerne noch einmal zurück melden. Bis dahin, dir/euch eine schöne Woche. Gruß Werkelkoenig -
Ich bin seit kurzem auch ein Besitzer eines kx41-3v bei dem einige Reparaturen anstehen. Ich würde mich sehr über das Handbuch und ersatzteilliste freuen viele Grüße martin
Thema antwortete Hydraulix's werkelkoenig in Baumaschinen Wartung, Reparatur & Diagnose
Hallo, Motor demontieren, versuchen am Ritzel zu drehen, händisch oder mit kleiner WaPu. Zange, geht dass , dann ist der Torqmotor platt, kann man nicht drehen, weitersuchen. hydraulix -
Hallo Hydraulix, vielen Dank für deine schnelle Rückmeldung. Verbaut ist ein Danfoss OMS 230 H, mit der Yanmarbezeichnung 172451-73311. Auf der Homepage von "https://www.yanmar-austria.at/" findet man die folgende Infos: Brauchst du noch weitere Infos zu dem Motor? Vorab vielen Dank und viele Grüße Werkekoenig -
Was ist der aktuelle Stand beim Thema Balkonkraftwerk? Was ist noch legal? Mit welchen Tricks kann man optimieren? Lohnt Balkonkraftwerk mit Speicher? Im Expert Talk mit Marc von @marctestet gibt es alle Infos über Balkonkraftwerk & einen Überblick über aktuelle Systeme. ► Bauforum24 TV Youtube Kanal Hier geht's zum vollständigen Beitrag
- werbung
- werbung
