SirDigger 2.651 Geschrieben vor 3 Stunden Geschrieben vor 3 Stunden On 8.2.2026 at 11:06, kenki fan schrieb: Most of the diggers in Japan have no quick coupler… Except demolition machines. It’s never necessary for regular diggers in Japan anyway. I Machines and no quickcoupler with an tiltinmg bucket is kinda a waste of possibilitys 1 Zitieren
kenki fan 143 Geschrieben vor 2 Stunden Autor Geschrieben vor 2 Stunden 47 minutes ago, SirDigger said: I Machines and no quickcoupler with an tiltinmg bucket is kinda a waste of possibilitys Indeed. But the problem is, unlike Europe, the auxiliary hydraulic system ( including pipes for attachments, attachment valves and even an extra gear pump and specialised joysticks) is not a standard equipment for diggers in Asia. Most of the diggers are just “diggers”, no chance to carry any attachments except buckets or grapplers drives by the bucket cylinder, not even a tilt bucket. Yes, what you can see is an arm with no pipes, nothing on it. In that sense, I think quick coupler is a kind of dead weight. About the tilt bucket, I found it useful, I will probably see it someday in Japan since Steelwrist has already entered the Asian market. Zitieren
kenki fan 143 Geschrieben vor 2 Stunden Autor Geschrieben vor 2 Stunden 1 hour ago, SirDigger said: I Machines and no quickcoupler with an tiltinmg bucket is kinda a waste of possibilitys Sry, tilt-rotator to be more accurate. Already seen it in both Japan and China, and only in exhibitions… Zitieren
