Hello,  I wonder can someone help me please.?
When I move the forward- reverse lever to neutral my kramer still wants to move forward.
It's not bad but annoying, if I rev the engine in neutral it moves forward a little, at idle it's OK...
Is there a valve that I can adjust the forward engagement?
Thank you very much from Ireland 🇮🇪!
Gary
  • 4 weeks later...
What is your oil pressure gauge showing?
It must show 0 bar in the neutral position
Thank you.
I need to install test points and gauges in the forward/ reverse hose line to check.
My old 312 sl does not have a gauge for neutral pressure...
I think I have figured out it could be the 3 o rings on the oil feed ring... I have not taken it out yet...
Thank you for your advice
